Hello, we use vmix to run a local tv station and there are some tv shows that are runned live, on air and on line (FB and youtube).
The "live" show have to be recorded without the station watermark ('case we replicate it during night schedule), and also the "analog" (hdmi) output have not to have the station logo, because is generated after by out playout server, BUT, i need to add that station logo to the stream out.
It will be usefull to have a "watermark" checkbox and a "browse" button to set the png to overlay so the streaming process could add the png over the PGM before passing the frames to the encoder.
Thanks a lot,
Federico Allegretti.
PS: maybe that behaviour could be obtained ina different manner, but at the moment i have not discovere it :D
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Check the overlay settings in the output settings where you can specify which overlay have to be applied to which output and play with the stream and recording outputs you want  overlays.JPG (52kb) downloaded 8 time(s).Unless you are sure there is no option then this is not feature request appropriate
