Feature Requests
Copy & Paste Shortcut Fields
Joined: 3/23/2020(UTC) Posts: 140  Location: Washington, DC Thanks: 41 times Was thanked: 25 time(s) in 17 post(s)
After spending hours programming and re-programming shortcuts for a few different setups I sure do wish there was a way to copy a field from one short cut and paste that value into a range of others.
For example you have 10 shortcuts that require the same button press. Would be super fast to copy from one and paste that value to a selection of the other 9.
I know you can clone and that works great For some things. However, there are times, particularly if you are reprogramming a new StreamDeck profile where you are moving a set of shortcuts from an existing preset into a new profile, to be able to copy and paste the button strings in particular.
Can I get a plus 1!
I will give this a +1 if vMix would also make the shortcut window expandable too ;-)
Feature Requests
