Where is the undo functionality?
I have worked with several platforms similar to vMix.
Every one has an "undo" functionality.
But I cannot find this in vMix.
For instance, if I have moved or resized something on a vMix stage, I cannot simply "undo" the change. There is no way to go "back."
This is extremely inconvenient.
Any solutions? Why has this common functionality been left out?
Joined: 1/27/2019(UTC) Posts: 37   Location: Bern Thanks: 5 times Was thanked: 8 time(s) in 7 post(s)
Originally Posted by: mitchellvii  I have worked with several platforms similar to vMix.
Aehm, and what about the „Reset“-Button at every Pan/Crop/Rotate/etc. slider???
Originally Posted by: ThommiTechnik  Ahem, and what about the „Reset“-Button at every Pan/Crop/Rotate/etc. slider??? Not that Reset is the same as Undo, of course....
save the preset with different names before any modifikations in the setup, so you can go back to different setups
