facundo
#1 Posted : Thursday, June 18, 2020 4:22:56 AM(UTC)
facundo
Uruguay
BUENAS SOY MEDIO NUEVO EN ESTO DE LOS FOROS ,TENGO UN DRAMA CON LAS CAPTURADORAS PINNACLE.
TENIA UNA CAPTURADORA PINNACLE CON UNA CAMARA QUE ANDABA IMPONENTE,COMPRE OTRA CAPTURADORA PINNACLE Y LA PUSE PERO RESULTA QUE NO LA RECONOCE,EH VISTO VARIOS VIDEOS DONDE USAN DOS CAPTURADORAS IGUALES MARCA MODELO ETC SIN NINGUN PROBLEMA.PERO ESTAS DOS MIAS NO PUEDO HACERLA QUE FUNCIONEN OSEA FUNCIONA UNA SOLA.LA NUEVA NO HAY FORMA DE HACERLA ANDAR ME SALE ERROR.
xaver
#2 Posted : Thursday, June 18, 2020 4:35:42 AM(UTC)
xaver
Please don't scream so loud and try to write in english.
facundo
#3 Posted : Thursday, June 18, 2020 4:45:49 AM(UTC)
facundo
Uruguay
GOOD I'M NEW MEDIA IN THIS FORUMS, I HAVE A DRAMA WITH PINNACLE CAPTURERS.
I HAD A PINNACLE CATCHER WITH A STUNNING CAMERA, BUY ANOTHER PINNACLE CATCHER AND PUT IT BUT IT IS NOT RECOGNIZED, I HAVE SEEN SEVERAL VIDEOS WHERE THEY USE TWO SAME CATCHERS BRAND MODEL ETC WITHOUT ANY PROBLEM. OSEA WORKS A SOLA. THE NEW ONE THERE IS NO WAY TO MAKE IT GO SALES ERROR
xaver
#4 Posted : Thursday, June 18, 2020 5:56:45 AM(UTC)
xaver
Do you have more information about the capture card / system ?
(btw. is your keyboard damaged, because you write all in capital letters?)
facundo
#5 Posted : Thursday, July 2, 2020 11:40:19 PM(UTC)
facundo
Uruguay
I still have the same problem the only thing that the capturer says is pinnacle system GmbH 710-USB Rev: 1.0 and the error I get is AddNewInput
Capture Device Is Not Supported, Device Reported the following: Video out
32595559-0000-0010-8000-00aa00389b71
Guest (5)
