Joined: 4/23/2020(UTC) Posts: 8   Location: Maresme Thanks: 5 times
Hello.
If i have a folder and remotely i can send to video files to this folder. Can i PUT this files in a "VIDEOLIST" automatically ?
Because if i can't acces to view Pc Vmix, but i can send the files to one folder in the Pc with Vmix.
Thanks.
Joined: 11/19/2013(UTC) Posts: 129 Location: Hobart Tasmania Australia
Thanks: 13 times Was thanked: 11 time(s) in 8 post(s)
Hi Srivelles
Not sure I totally understand, but you can try below to add a list of MP4 files in a Folder to a List
If you have vMix 4K or Pro add the below as a script
-------------DirFilesToList---------------------------------------------------------------- Dim di As New system.IO.DirectoryInfo("D:\YOURDIRECTORY") Dim fi as system.io.fileinfo() = di.getfiles("*.MP4") dim f as system.io.fileinfo
for each f in fi API.Function("ListAdd","List",f.name ) next f
So dump your files into a remote machine directory
Run the script on the remote machine with vMix
http://YOURWANIP:8088/api?Function=ScriptStart&Value=DirFilesToList
 3 users thanked Ash for this useful post.
Joined: 12/27/2012(UTC) Posts: 5,541  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Hi Doggy
Yes my error
Will repost in the other Topic
Ash
Thanks: 1 times Was thanked: 6 time(s) in 6 post(s)
Thanks: 193 times Was thanked: 20 time(s) in 17 post(s)
Many thanks Ash !
I think the f.name must be changed to: f.FullName
This would produce this script then:
for each f in fi API.Function("ListAdd","List",f.FullName ) next f
 1 user thanked Ario for this useful post.
