multiple live streams from different cameras.
Joined: 7/3/2014(UTC) Posts: 4 Location: Scottish Border
Hello, At the moment I have two pcs running Basic HD which enables me to stream two wildlife cameras to YouTube/my website. Other than adding a third pc is there another way by which I could stream an additional camera?
Originally Posted by: justcurious  Hello, At the moment I have two pcs running Basic HD which enables me to stream two wildlife cameras to YouTube/my website. Other than adding a third pc is there another way by which I could stream an additional camera? One can stream to 3 different locations simultaneously upgrade and one can do it with 2 separate cameras (inputs) in your case upgrade one to stream 2 cams separately and retain the other HD license for the 3rd cam or one can multi view the cameras to one stream :-) or have all 3 cams in a 360 virtual set (1 stream) and viewers can move the field of view to look at another camera ;-)
Thank you for your reply but which version do I need to upgrade to. Looking at the specs. for each version I cannot see which one would allow me to stream two individual cameras. Regards.
4K  4k.JPG (22kb) downloaded 3 time(s).
Thanks again Doggy, So to achieve this I would need to have the 4K,$700 version. Being of limited means and an amateur this is out of the question. However I do appreciate your advice. Regards.
Originally Posted by: justcurious  Thanks again Doggy, So to achieve this I would need to have the 4K,$700 version. Being of limited means and an amateur this is out of the question. However I do appreciate your advice. Regards. Understand but what is an extra laptop going to cost you ? Also do not forget one can upgrade a current license by paying the difference (and have many more possibilities to boot) Something else to think about is the possibility to stream one of your NDI outputs (4) and stream it with a little external app
I think the easiest way is to tick the box for outputting each input as NDI and then pick the NDI and send to whatever streaming device
