How to build a virtual set?
Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
The website suggests it as a possible option,however the manual does not discuss what is needed to build a virtual set. All I want to do is build a screen that will be behind my subjects that I can resize in order to cover up the chroma screen. Does this make sense and if so,then please direct me on how to proceed.
Thanks,
vidkid
 1 user thanked vidkid for this useful post.
Joined: 11/21/2013(UTC) Posts: 4  Location: Malaysia Thanks: 3 times
in my situation, i'm just replace the background image in virtual set folder.
Joined: 11/14/2012(UTC) Posts: 402  Location: Finland Thanks: 256 times Was thanked: 39 time(s) in 37 post(s)
vidkid wrote:The website suggests it as a possible option,however the manual does not discuss what is needed to build a virtual set. All I want to do is build a screen that will be behind my subjects that I can resize in order to cover up the chroma screen. Does this make sense and if so,then please direct me on how to proceed.
Thanks,
vidkid Yes, vMix should have more flexible and advanced virtual set editor and documentantion on it. Maybe in v12? Kind regards, Jan Tervo - - - - - Tally+Intercom Solution: http://kuvauskomeetta.fi/ti/- - - - -
zul.ms wrote:in my situation, i'm just replace the background image in virtual set folder.  Hello @zul.ms I am interested to know how you do the sets and what programme... Thanks
I am trying to recreate this exact set...
Any ideas how I can create this
