davidcl
#1 Posted : Sunday, June 14, 2020 8:40:09 PM(UTC)
davidcl
Gabon
hi
I have a question (sorry for my english And its very diffult for me to explain the problem)
i have to make a stage .
On the presenter i will put a return audio (BUS A for example) with all elements/video i will receive during the show.
But when i want to give him an information during the Live (so during and video in live) how i can 'cut' the audio signal going on the stage (bus A) and ONLY listen to me (Mic producer)
For now ,i have the video sound going on return stage but when i talk the signal of all videos is alway present.
I want to cut (all videos/ generic/jingles/..) and just listen the producer micros (without manualy cut bus A on the videos/elemnts/.. because during the show in live i will receive some ones via whatsapp ,....
What i think is:
1) sending all video/generic/.. on bus A
2) Mic prod on bus B
3) the speacker on stage connect on BUS B
4) if i dont active the shortcut the signal BUS A go on BUS B
5) when i active the shortcut bus A cut so only my prod mic go on the stage return
But i dont know how doing this CROSS?
i hope you will understand?
En francais:
jai deja le shortcut pour parle sur le bus A qui va au plateau.
Le probleme cest ke jai en meme temps les video. generiques, jingles qui sont diffuses qui sont bien entendu sur le retour plateau.
Je voudrais que lorsque je parle ca puisse desactiver les sons autres, seulement mon micro producteur.
Sachant que durant le show en live je vais recevoir des elements donc penser pendant la real a fair des manips de raccourci supplement pas facile.
Ce que je pensais c etait d envoyer TOUT les elemnts dans le BUS A
le micro PRODUC dans le BUS B
L enceinte ki va dans sur plateau connecte sur le bus B
si pas de shortcut (micro prod) le bus A va dans le bus B
si shortcut BUS A coupe dsns le BUS B donc seulemtn le mic prod passe?
En esperant avoir ete assez clair???
dmwkr
#2 Posted : Sunday, June 14, 2020 10:37:20 PM(UTC)
dmwkr
If I understand you correctly, you could:
1) Make sure Bus A and B are routed/connected to the same speaker on stage.
2) Create a shortcut that mutes Bus A and unmutes Bus B.
3) Create a shortcut that mutes Bus B and unmutes Bus A.
4) If you have a MIDI controller you can do it with one shortcut, on pressing (2) and releasing (3) the button.
davidcl
#3 Posted : Monday, June 15, 2020 1:35:57 AM(UTC)
davidcl
Gabon
i have use DANTE
Yamaha / RIO
I CANT have phycially on the Output (for example : 1 (/busA) and 2 (/bus B) so the SPEACKER is on XLR output 1 or 2 it cant be on 2 output for 1 speaker?
#4 Posted : Monday, June 15, 2020 1:47:40 AM(UTC)
Salut David
davidcl
#5 Posted : Monday, June 15, 2020 2:00:02 AM(UTC)
davidcl
Gabon
Yes i see that i use for my Vcall and working well
But its not the same thing i think.
because when i talk on stage i want that all CUT and only my mic director!
