Josemite
#1 Posted : Thursday, June 11, 2020 6:10:48 PM(UTC)
Josemite
I might just be super dumb, sorry. I've watch numerous videos and read other post, but I'm missing something about this. I've basically spent half a day just trying to figure this out.
As the host, I add an Audio Input & use the checkbox [X]option to 'Mute in headphones' but the guest caller can't hear me. If I use the gear icon on that Audio Input and click the headphone icon to green, then I start hearing myself my headphones... but then the guest can hear me too.
I just can't figure out a way to be host and hear the guest, but not hear myself in my own headphones.
dmwkr
#2 Posted : Thursday, June 11, 2020 7:07:17 PM(UTC)
dmwkr
Check the audio source you are sending to your guest by right-clicking on the call input:
https://www.vmix.com/help23/vMixCallMenu.html
thanks 1 user thanked dmwkr for this useful post.
Josemite on 6/11/2020(UTC)
Josemite
#3 Posted : Thursday, June 11, 2020 7:25:06 PM(UTC)
Josemite
That solved it, thank you!
I see now where I went wrong. The default Audio Source for me when adding a Video Call, was 'Headphones' & switching that to 'Master' fixed it... in combination with creating a Audio Input using the 'Mute headphones' option.
Thanks for info on right clicking the callers in order to change the Audio Source, it would have been a bummer to have to create them from scratch.
screenshot Vmix Caller
Mute in Headphones
Guest (4)
