SRT
Is anyone using an AMD graphics card with SRT?
Joined: 5/8/2020(UTC) Posts: 10  Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
In the VMIX tech/system requirements for SRT is says:
Windows 10 x64 or higher Graphics card with support for HEVC and H264 encoding and decoding. NVIDIA Quadro P2000 or higher series recommended. NOTE: NVIDIA GeForce 9xx series or lower should not be used with SRT, and is unsupported.
I'm wondering if anyone is using the AMD equivalent of an NVIDIA GTX 1050 or higher and has success with adding SRT listener inputs into VMIX
thanks!
I'm running a RX580 8GB ... no problems with SRT.
Joined: 1/25/2019(UTC) Posts: 335  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
yes, Intel Nuc with AMD RX Vega M GL. SRT OK, but only H264.
SRT
