emissione
#1 Posted : Tuesday, June 9, 2020 9:35:43 PM(UTC)
emissione
Italy
Salve a tutti da qualche giorno sto riscontrando problemi con il vmix, non mi carica più il mio ponte (https), mi compare la finestra nera e me lo fa con altri pc che hanno il vmix,se invece inserisco la stringa nella pagina internet funziona. io ho un vmix4k aggiornato alla versione 23.0.0.54
#2 Posted : Tuesday, June 9, 2020 10:09:35 PM(UTC)
are you talking about using https in a webbrowser input ? not sure I understand what you mean by "mio ponte (https)"
emissione
#3 Posted : Tuesday, June 9, 2020 10:39:05 PM(UTC)
emissione
Italy
I transmit an rtmp signal via camera and with the vmix (stream / srt) I take the signal (https), but now it doesn't work anymore. sorry for my english
#4 Posted : Wednesday, June 10, 2020 12:59:25 AM(UTC)
Don't worry for your english, my italian is very bad !
for RTMP streams, you should use an url starting by rtmp:// or rtmps://
for SRT streams, it's srt://
if your stream url starts with http:// or https://, it's not RTMP protocol but HLS, DASH or MPEG/TS. Here I think it's most probably your camera web interface... not the stream itself.
I think your camera can stream several protocols at the same time and it has a builtin web server to show the video inside a player, this explains why it works in a web browser but in vMix you must select the right stream type when adding your input.
So make sure which protocol is used by your camera, it can be RTMP, RTSP, HLS, MPEGTS or SRT for example and use the correct address to play the stream in vMix. You should see this either in your cam manual or in your camera web interface
Hope this helps
