Stonys
#1 Posted : Tuesday, June 9, 2020 8:07:56 PM(UTC)
Stonys
Lithuania
Is there any way to trigger VirtualSet input zoom presets with stream deck?
#2 Posted : Tuesday, June 9, 2020 8:23:48 PM(UTC)
yes. As indicated in the manual, use selectindex command
https://www.vmix.com/help23/
Stonys
#3 Posted : Friday, June 12, 2020 3:37:29 AM(UTC)
Stonys
Lithuania
I did not put enough information in my question. My problem, I need to map Virtual set zoom positions on StreamDeck using Companion software. There's selectindex shortcut when using StreamDecks software, but I can't find it on Companion.
Any thoughts? There's custom command function, but I can't find any information on how to form it.
#4 Posted : Friday, June 12, 2020 4:02:16 AM(UTC)
Guess that's a question for a companion group then ?
Stonys
#5 Posted : Friday, June 12, 2020 5:00:59 AM(UTC)
Stonys
Lithuania
Smart stuff. Thanks anyway. I'll look for an answer there.
Case closed
MRedZac
#6 Posted : Friday, November 29, 2024 5:57:12 AM(UTC)
MRedZac
Germany
Easy: Just create new inputs at different zoom levels needed and link them with companion.
I am sure, there are more complicated ways, but this one works reliable.
Enjoy !
