dbroo
#1 Posted : Tuesday, June 9, 2020 6:29:03 AM(UTC)
dbroo
Hi there...
I'm relatively new to vMix. I'm using it on both my desktop and my MS Surface. On the desktop, I have the toolbar at the bottom with a button towards the far right that says "overlay". I can use that to change the overlay parameters. However, on my Surface, I don't see the overlay button. Obviously, the surface has the smaller screen and I believe it just isn't getting on to the real estate. Is there any way to change the tool bar to return the overlay button? Can I customize the toolbar to get rid of the elements I don't use?
Thanks for your help.
mavik
#2 Posted : Tuesday, June 9, 2020 7:19:50 AM(UTC)
mavik
have you tried running vmix app on the surface in full screen size?
dbroo
#3 Posted : Tuesday, June 9, 2020 10:33:45 AM(UTC)
dbroo
Yes. It didn't make much of a difference.
Guest (4)
