Paul LAURENT
#1 Posted : Sunday, June 7, 2020 9:17:00 AM(UTC)
Paul LAURENT
I recently wanted to reinstall vMix on my computer. After registering my license and configuring the startup parameters, the vMix logo displays for some time on my screen and I barely have time to see the interface before it closes immediately, I suppose that the we can consider this as a crash. For information, I use a vMix 22 license which worked perfectly a few months ago on this same computer. I then tested on another computer, same problem, and I even asked a friend to simply try the trial version on his computer and he has exactly the same problem. I tried different things like checking that the .NET framework was correctly installed on my computer but it was correctly installed and it didn't change anything. I also tried to install the trial version of vMix 23 on my computer and it works perfectly!
I'd be thankful for any advice !
