Hardware Compatibility
Happuage HDPVR 1212 Capture Card Not Working In Vmix
Hey, so I've already gotten used to Vmix which is an awesome program but when I input my HDPVR Capture card it won't work/doesn't let me, I've tried everything to try to fix it but no luck. Can anyone help me, or is my capture card not compatible with Vmix?!?
Joined: 6/29/2011(UTC) Posts: 316   Location: Florida Thanks: 6 times Was thanked: 35 time(s) in 34 post(s)
I have tested them and no luck with vMix. I also spoke with them about drivers for windows to allow vMix to see the card and got nowhere. The one thing that really bothered me was even with Happuage's recorder there's a huge delay which made it useless for me.
Joined: 2/9/2013(UTC) Posts: 266 Location: Katy, Texas
The Avermedia Live Gamer Portable is a similar device that does have software that allows the video to be used by programs like vMix. I use it to record HD video. I haven't tried to use it as a source in vMix.
TheKV wrote:Hey, so I've already gotten used to Vmix which is an awesome program but when I input my HDPVR Capture card it won't work/doesn't let me, I've tried everything to try to fix it but no luck. Can anyone help me, or is my capture card not compatible with Vmix?!? I tried this tried and have to return ot because it was not detected by Vmix. Bought AverTV instead and it works out of the box, no complicated settings and a lot cheaper.
