Toby
#1 Posted : Thursday, June 4, 2020 4:49:10 AM(UTC)
Toby
Israel
Hi all,
is there any possibility in vMix or with a workaround to stream 4 streams in parallel? We require to stream the same video with 4 different audio tracks (languages), however vMix supports only 3... very much liked vMix as it is so user friendly. But as it seems that there is not such an option, we are right now looking at Wirecast which is not limiting the number of streams, but Wirecast seems to have other limitations...
I would appreciate your feedback.
Thanks,
Toby
jip
#2 Posted : Thursday, June 4, 2020 6:24:24 AM(UTC)
jip
Estonia
I would propose experimenting with OBS or similar which could be used as extra encoder via NDI outputs.
However, it might be difficult to achieve more accurate synchronization between vMix and external encoder streams, if that's important.
ask
#3 Posted : Thursday, June 4, 2020 10:34:28 AM(UTC)
ask
Originally Posted by: Toby Go to Quoted Post
Hi all,
Thanks,
Toby
Simply install a vMix Basic HD on another PC/Laptop. Bring in the stream via NDI and configure the additional streaming destinations. By using two systems you will reduce the CPU overheads on your main machine and now you have the possibility of 6 destinations.
