vMix & Zoom audio routing issues
Hi guys... hope anybody can help me..
i am running vmix on one machine and zoom on another
i have issues with the audio routing..
has anybody done a successfull connection like this and if so can you share your installtion and setup with me.
i need to get this working urgently so i can assist my clients
Regards Francois South Africa
Rank:: Advanced Member
Joined: 6/2/2020(UTC) Posts: 67   Location: Berlin Thanks: 8 times Was thanked: 9 time(s) in 8 post(s)
Hey i did somting like this with Skype and with other Platforms and Tools also with Jitsi and Zoom.
You need to configura a N-1 Audio sum. Wich means: you send every audio source you get exept the zoom-audio in to zooom.
You do as follows:
Create a bus, bsp. BusG send attach all inputs to BusG(not the zoom) configure an external audio out of BusG
Connect the physical output of BusG to the Ohysical input (audio interface) of the Zoom computer. Connect the Zoom Output to the Audio input in vMix hooked up with the Zoom video signal.
here you go.
Or do you want to do it over the same machine?
Greetings Paul
Hi Paul
hope you are well
thanks so much for your response...
sorry it took me a while to write back... was just busy in the studio with a client...
i am back at my normal desk tomorrow so i will write back to you with picture of my setup...i will make it simple and just use one zoom connection, one vmixcall connection and one cam input with my mic/headset setup to simplify my setup and problem.
i hope thats ok and that you will then be in a position to point out where i am going wrong.
i will take pictures of all my setting on my main vmix pc as well as each setup on my zoom pc running a second vmix installation as per the instructions from tim at vMix
thanks again so much for your time and hope you dont mind me giving you all the info as i really help...
thanks again in advance.
Regards Francois Kotze South Africa
