davidcl
#1 Posted : Tuesday, June 2, 2020 8:58:32 PM(UTC)
davidcl
Gabon
Hi all
I have to make a new challenge
* 10 videocall (vmixcall/skype/zoom? ) + 1 (meeting room whre system will be install)
* 4 languages (for that no problem BUS A B C D E) each there languages
But for the 11 video call ??
Vmix only 8 ?
How i can do?
Zoom impossible (because i think impossible to send a BUS different for each ?)
Skype possible??
Please help me
What do you think
8 vmixcall + 2 skype?
or only in skype?
or other?
Thanks a lot!
David
srbh41413
#2 Posted : Wednesday, June 3, 2020 1:20:42 AM(UTC)
srbh41413
Japan
Hello from another rank newbie.So, take the following for what that's worth...
I have been able to bring in 3 Skype callers using NDI on the same machine (not the screen/window capture method
vmix recommends, but directly from NDI output of Skype).
The 3 callers were in group Skype call. You have to use the Content Creator version of Skype to get the NDI out.
Once that is working, get the group Skype call with ten people connected.
If you create an NDI input, you should see each caller in its own window to choose for that input. There will also be 2 extra; one for 'local' which is you and one for 'active speaker' which is what it says. Usually you should see each account name in the input window top border.
You have to create nine more inputs to have an input for each caller. (Need sufficient version of vMix)
If you want to combine callers in one screen, make a base input and then do multiview overlays choosing from the multiview drop-down menus, and resize/reposition them with the POSITION menu.
This much is working for me, but then comes the challenge of routing the sound correctly. There is a tutorial about connecting Zoom from same computer which I believe should work with Skype, too. I'm struggling through this part now.
If anyone can explain why doing as above is a bad idea compared to the window/screen capture method, I would appreciate hearing. As long as the PC is high enough spec, it seems to work.
Please share any successes.
srbh41413
#3 Posted : Wednesday, June 3, 2020 1:27:40 AM(UTC)
srbh41413
Japan
About sending 4 languages - if you mean sending 4 languages selectively to individuals on the group Skype call, then no. Skype sends everyone the same sound. Even though we can receive them separately, we cannot send to them separately because it's Skype's world at the end of that chain.
Zoom has an interpreter function if you have business account. But, it depends on interpreters manually clicking when they change languages back & forth. So, that would be quite a stretch to use that in this case. Maybe you can use that in a different configuration...
davidcl
#4 Posted : Wednesday, June 3, 2020 1:38:14 AM(UTC)
davidcl
Gabon
Yes i need to send different sound (4 languages) for each people.
So skype non good if i cant send a special BUS for each
So the best solution is VMIXCALL
but i have 10 people (visio)
only 8 call on vmixcall
Can i use another machine with another license and have 2 more vmixcall and take it via NDI in my Principal machine?
Thanks a Lot
David
srbh41413
#5 Posted : Wednesday, June 3, 2020 1:51:03 AM(UTC)
srbh41413
Japan
I'm not expert at all, but that is the direction I would think to do. Very brave of you.
srbh41413
#6 Posted : Wednesday, June 3, 2020 1:52:44 AM(UTC)
srbh41413
Japan
You might also want to look at Zoom's interpreter function...
mjgraves
#7 Posted : Wednesday, June 3, 2020 2:04:01 AM(UTC)
mjgraves
Good luck with that. I work for the company (ZipDX) that they used as a reference when they researched that feature. We've been doing multilingual conferencing for ten years. They only implemented about 30% of what's required to do it right. As a result, the Zoom function has limited application.
srbh41413
#8 Posted : Wednesday, June 3, 2020 2:42:05 AM(UTC)
srbh41413
Japan
@mjgraves - thank you for that input. I've only checked out Z on this and for our use, it has a huge limitation in that once the interpretation feature is engaged, no one can hear just the original meeting - i.e. people who understand all the languages are forced to listen to interpreter for half the time (in the case of two languages).
I'll surely check out ZipDX.
If you would like to point out anything else, would be glad to hear.
though I guess we are getting of topic...
Paul Fuhrmann
#9 Posted : Wednesday, June 3, 2020 3:37:10 AM(UTC)
Paul Fuhrmann
Germany
Was thanked: 9 time(s) in 8 post(s)
Hey for a that big you should consider using Zoom only.
Idid a 54Person Konference (international politics) in Zoom only. (Iwas AudioEngeneer on the German Host Facility)
Each Member selects the audio he wants to hear.
And each defines what language he speaks(very importand).
the Interpreters define they are intrepreters to a specific language and waht they are able to hear.
and than everything is fine.
you will need for every translation direction an separate interpreter. bilangual interpretation in zoom with togeling os not comfty for interpreters. Also consider only sending english only to zoom and have interpreters on location where needed. ( much more simple and more control)
Greetings Paul
thanks 1 user thanked Paul Fuhrmann for this useful post.
srbh41413 on 6/3/2020(UTC)
mjgraves
#10 Posted : Wednesday, June 3, 2020 3:45:41 AM(UTC)
mjgraves
ZipDX is an audio conference service. No video. We have a patented system for simultaneous interpretation over-the-phone (or computer.) It requires professional conference interpreters.
We do not support integration with third party platforms like Zoom, Webex, GotoMeeting, vMix, Wirecast. All that means is that if you want to do that, you do it on your own.
srbh41413
#11 Posted : Wednesday, June 3, 2020 11:19:03 AM(UTC)
srbh41413
Japan
@Paul Fuhrmann - regarding Zoom interpretation function, we have uses with individual interpreters doing both directions of language pair, i.e. clicking as they change back & forth. As you say, not comfy, but doable. For us the deal breaker with Zoom system is that there is no way for multilingual attendees who don't need interpretation to hear the raw meeting only.
This is a function that ZipDX does have and probably there are others.
thanks 1 user thanked srbh41413 for this useful post.
Paul Fuhrmann on 6/4/2020(UTC)
Paul Fuhrmann
#12 Posted : Thursday, June 4, 2020 2:10:28 AM(UTC)
Paul Fuhrmann
Germany
You can use "Floor" in Zoom but you need to define it.
Find a language nobody uses and define it as floor. all ettendees who want to listen to the oroginal signal need to select your defined floor signal.
Is video something you need? If not switch to ZipDX if you need video it gets realy ugly combining ZipDX with Zoom (It will work but the track active speaker will not work as expected. only the person where you plug in the audio from ZipDX will show up automaticaly.)
You can use the raise your hand feature to identify who speaks. And then force Spotlight the person for all.
Guest (5)
