DataSource Photo is Sideways
I have a simple yet frustrating problem. Photos linked through dataSources are coming in sideways. The photo looks correct in Windows explorer and opens correct in Photoshop. Opening the photo and re-saving is not updating the photo metadata for the correct angle. Opening the photo up in Windows Photos shows the incorrect orientation - and rotating the photo corrects the rotation - and the next time I open the photo in Windows Photos does show the correct orientation. HOWEVER, vMix still shows the incorrect orientation. I am loading more than 1000 photos so I need to find a way to get vMix to show the correct orientation.
If I have to save the photo with a different file name - this will get complicated as the spreadsheet will then be wrong.
Any ideas?
What title are you using ? file type of your photos ?
