jldpaula
#1 Posted : Monday, June 1, 2020 2:45:54 AM(UTC)
jldpaula
Spain
HI,
We are looking to build a system for record/control 4 PTZ cameras (using blackmagic capture card), maybe some grapichs and no so much more...the opal system reference will be enough for this?
Also, can be the possibility of recording the output when doing the streaming + the 4 camera input signal for further postproduction (+ audio signal)
fonty33
#2 Posted : Wednesday, July 29, 2020 4:38:16 PM(UTC)
fonty33
HI
The new opal system should work fine for what you need thou this does depend on what bitrate and res you want to stream and record at ?
you could upgrade the processor to a 3700x and buy 2070 Card which wouldn't cost that much extra and would give room to grow.
D
