Good afternoon
i have followed the zoom to vmix integration on 2 pc's as per instructions
as soon as u talk to the zoom connection via your mic/headset on channel A u get your own voice back and as soon as you connect a webcall to vmix and u have a zoom connection as well u have to send wecall audio to Channel A and then you get master audio back again to wecall meaning u hear your own voice comming back on webcall
i have spend almost 20 hour on this installation done it 17 times over and over again but no success.... webacal into vmix with mic talk back and using headset no audio feedback as soon as u activate channel A u get audio feedback as is sends it back into master..
has anyone on the forum had anny issues with zoom audio and if so how dit u fix it.. i am so desperate
Originally Posted by: Francois001  i have followed the zoom to vmix integration on 2 pc's as per instructions Which one ? There are hundreds
i have followed the instructions of running zoom and vmix on 2 seperate pc's that vmix published on the training site.... why do u have a different method of doing it .. as i am battling this is the method i am using https://www.vmix.com/kno...h-return-video-and-audio
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
Here is a shot in the dark: Have you muted the headphones in vMix on the Zoom PC, like in Step 1d) mentioned?
I'm using vMix with zoom and don't have a problem with feedback at all. As mentioned, I have the audio input muted in headphones. I do have a problem with audio lag, but nothing else.
Thanks guys...... i went on the fb vmix group and there i picked up a person who helped me with my installation and connection with zoom running zoom on another pc with 7 vmixcall connections and instudio camera and mic with audio playback on front of house speakers... so all sorted thanks
