Record audio delay not working
Joined: 12/3/2019(UTC) Posts: 10  Location: Russia Thanks: 3 times
Hi all!I have a problem with the work of audio delay while recording. The delay setting for negative delay is not applied. Positive also does not work.Record Setup negative audio delay:  Record Setup negative audio delay.png (13kb) downloaded 1 time(s).Negative audio delay (Video delay) not apply:  Record negative audio delay issue.png (164kb) downloaded 1 time(s).Also negative audio delay on external output:  External Setup negative audio delay.png (22kb) downloaded 0 time(s).Work!  External negative audio delay Working.png (163kb) downloaded 0 time(s).Record Setup positive audio delay:  Record Setup positive audio delay.png (13kb) downloaded 0 time(s).Negative audio delay (Video delay) not apply:  Record positive audio delay issue.png (163kb) downloaded 2 time(s).Any ideas?
Joined: 1/13/2010(UTC) Posts: 5,322  Location: Gold Coast, Australia Was thanked: 4726 time(s) in 1618 post(s)
The statistics shown in your screenshot is for processing latency and is not the same as the delay. The delay is embedded in the recording directly.
I have just completed a vMix AVI test and can confirm the audio is delayed in the recording as expected.
Martin vMix
I did a test, positive delay really works. But the negative does not work. Screenshot:  Issue.jpg (251kb) downloaded 1 time(s).Scheme:  Scheme.png (22kb) downloaded 0 time(s).Sync file:
I had the same "problem" years ago and Martin told me "only positive delay will work" you can setup a negative delay, but this will not work
I don't think, they have changed it. For my opinion, it would be better, if it's not possible to setup a negative delay (because it's not working)
so you have to find a solution to delay the video
 1 user thanked xaver for this useful post.
The manual says that when recording a negative delay should work.  Manual.jpg (360kb) downloaded 1 time(s).I conducted tests with both the master bus and the a bus - a positive delay works, but a negative one does not. Martin, is that how it should be?
