Hardware Compatibility
Sonnet’s Echo Express SEIII + DeckLink Quad HDMI Recorder
Hello everyone, Does Vmix work with a DeckLink Quad HDMI Recorder Capture Card, which is built into an external Sonnet's Echo Express SEIII and connected to a Windows PC via Thunderbold 3? I found this tutorial once: https://9to5mac.com/2019...video-capture-enclosure/Thanks to all!
Joined: 3/7/2012(UTC) Posts: 2,689  Location: Canada Thanks: 33 times Was thanked: 512 time(s) in 480 post(s)
@ TMClive
The issue will be the bandwidth. The DeckLink Quad HDMI Recorder is a x8 card which will be pushing the limits of a Thunderbolt 3 connection (if all ports are connected). A single Thunderbolt 3 port is generally equivalent to a PCIe 3.0 x4 slot. Many Thunderbolt enclosure manufacturers are touting connectivity for x8 and x16 cards, however, I think that is somewhat misleading because as I understand it, the maximum connectivity you can get is x8 via a dual port connection (which they don't really disclose).
I hope that puts things in perspective somewhat.
