seb666
#1 Posted : Wednesday, May 27, 2020 8:45:17 PM(UTC)
seb666
shouldn't the vMixCalls stay in one resolution, when I have a fixed bandwidth? I recorded them with MultiCorder and one of my callers produced over 30 files which have multiple frames (over 40) dropped while the files changed. So this is no suitable material for a later cut. Would be great to have that working better in future releases.
Seb
#2 Posted : Wednesday, May 27, 2020 8:50:39 PM(UTC)
Was thanked: 4733 time(s) in 1623 post(s)
Hi Seb,
This is controlled by the browser's own internal bandwidth management logic and not something vMix has any control over
(other than basic settings like bandwidth limits).
Using vMix on both ends is the only way to ensure a consistent feed for MultiCorder purposes
otherwise you will need to use the vMix Outputs instead.
thanks 3 users thanked admin for this useful post.
seb666 on 5/28/2020(UTC), mjgraves on 5/29/2020(UTC), eduardocfs on 6/1/2020(UTC)
