vMix Call
Audio shuts off on one vMix Call session when not selected
Joined: 12/29/2018(UTC) Posts: 21  Location: Sydney Thanks: 3 times
Hi All -
I'm running a setup with myself as host in the studio with vMix, plus 2 VMC (Vmix Call) sessions. I have audio mix auto set to on for both VMC sessions. When I select the second VMC session for fullscreen, the audio automatically shuts off on VMC session 1. Same if I select another input such as a video - the audio for VMC session 1 shuts off and has to be manually turned back on unless I choose a virtual input with VMC session on it, however for VMC session 2 the audio (and green Audio button on that input) stays on no matter what I select for other inputs.
Any ideas?
Thanks,
Mark N.
Joined: 2/23/2019(UTC) Posts: 139  Thanks: 20 times Was thanked: 29 time(s) in 26 post(s)
In the audio mixer find the vmix inputs and click button with green and yellow arrows so as it is grey. That will stop vmix automatically muting the input when it is not visible.
Another way of doing the same thing is to click the cog icon on the input, then on the General section there is a tick box for Automatically mix audio. Unticking that does the same as above.
 1 user thanked RichDanby for this useful post.
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
vMix Call
