jip
#1 Posted : Friday, May 22, 2020 2:04:22 AM(UTC)
jip
Estonia
I have the following feature request:
Currently "Automatically mix audio" mutes or unmutes the entire audio input regardless of its assigned audio buses.
However, it would be useful if automatically mix audio could be switched so that it affects the input routing to buses, for example Master bus, while keeping audio input active all the time.
Hence, automatically mix audio would target muting/unmuting desired bus instead of entire audio input.
Use scenario: Webinar via vMix Call with remote guests and remote event chairman:
-Master audio bus to live output
-Buses A and B are used for "green room" as well as talkback from the studio to remote guests
-Everybody's incoming audio is by default included in the "green room" buses so that everybody can hear each other before going live
-When remote participants are joining the live broadcast from green room, their audio will be added in Master bus (obviously).
In such scenarios it would be most useful to be able to use "automatically mix audio to bus" to include the guest's audio to Master when going live.
SamD03
#2 Posted : Monday, May 25, 2020 8:23:22 PM(UTC)
SamD03
I posted this exact feature request a few weeks ago here: https://forums.vmix.com/...ather-than--AUDIO-ON-OFF
+1!
stigaard
#3 Posted : Monday, May 25, 2020 8:29:05 PM(UTC)
stigaard
Denmark
How about using triggers?
On the input you can setup OnTransitionIn triggers to turn on AudioBus. And then on OnTransitionOut turn off the necessary busses again.
