Microsoft Teams integration
You have been a member since:: 5/4/2020(UTC) Posts: 1  Location: Bucharest
Does vMix Call support any integration with Microsoft Teams to allow Teams users to connect to the live event? Or any other type of integration?
Thank you Lucian
Joined: 5/10/2020(UTC) Posts: 1  Location: Rio de Janeiro
I have the same request, I'm just wondering how to bring 3 people from a Microsoft Teams Call inside VMix and so work over it as regular VMix production. I will try to use the screen capture region but as it will be a none control audio, looks like not a professional solution... Hope to hear another ideas from Vmix crew and or the VMix community. Thank you very much in advance. @SantosLeandroDP
Joined: 5/12/2020(UTC) Posts: 1  Location: las palmas
Hello, I would also like to integrate Microsoft Teams into vmix
Greetings thanks
Joined: 5/24/2020(UTC) Posts: 19  Location: Tokyo Thanks: 8 times Was thanked: 1 time(s) in 1 post(s)
Another vote for Teams integration. Although I believe it's on Microsoft to enable NDI out from Teams as in Skype... For the time being, I plan to have presenters gather in a group Skype call and then create an input for each caller from NDI. The only thing that seems to be missing is the ability to create the inputs ahead of time so that when the presenters' Skype calls come in, they just appear in their inputs. This function exists in x-split and works well there. As long as you know the incoming Skype account name.
Joined: 12/10/2016(UTC) Posts: 126  Location: Frankfurt, Germany Thanks: 93 times Was thanked: 19 time(s) in 14 post(s)
First of all: there is a "Feature Request" section in this forum. That's where this thread belongs. And at the moment it's possible at the moment to insert guests from MS Teams via screen capture. This video gives an idea how to do that: But luckily Microsoft is developing NDI output for Teams, so in the very near future you can use it like Skype in this tutorial:
 1 user thanked seb666 for this useful post.
@seb666 thank you very much. That's great news that MS will enable NDI in Teams soon. I hope it will work as in Skype where each 'caller' can be picked up as a separate source.
The screen capture method to bring video conference guests in gets quite difficult when there are several people who need independent frames.
Thanks again.
