Feature Requests
GT Designer Advanced - Change effects based on Data Sources
Joined: 5/22/2020(UTC) Posts: 2  Location: NYC Was thanked: 1 time(s) in 1 post(s)
I'm trying to create an interactive chart where I use a rectangle and change the look of the rectangle through data sources.
Example: If I could link an effect such as (Effects>CropX1) to a data source.
So I can set up a formula that converts a ((fundraising amount/fundraising goal) * 100) For example: $20,000/$150,000 = 0.13 x 100 = 13. Now I would like to take the 13 and map it to the CropX1 in realtime.
 1 user thanked SF89 for this useful post.
I would like to use data sources to change colors. I have created a rundown excel sheet to change a bunch of stuff before a game, but I always have to change colors manually.
I think my problem could be solved with your solution.
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
@SF89 & @rnhturner
Requests are often made when a sudden need arises for a particular production in which case updating (if) vMix an GT title will take much longer to fulfill than the current need
All those things are possible using legacy XAML titling , there is nothing wrong with using some legacy stuff , in fact for such special things its still is more powerful then GT titles
These wishes have been addressed and solved for XAML titles multiple times in this forum
Regarding the chart for example if you dont want to use XAML, playing with multiviews , with graphics and even titles in it an a bit of vMix scripting you can get a long way to achieve this for now .
a bit of out of the box thinking helps if your really want such things NOW (not to mention external applications)
Feature Requests
