Feature Requests
Would it be possible to get an indication in vMix Call about which connection type is in use?
Joined: 3/28/2017(UTC) Posts: 70   Location: Haapsalu, Estonia Thanks: 75 times Was thanked: 3 time(s) in 3 post(s)
Would it be possible to get an indication in vMix Call about which connection type is in use? For example, STUN (Peer-Peer) or TURN (via Call server). That would be useful both for assessing the trustworthness, as for perhaps initiating a firewall examination in order to open up for STUN.
Thanks: 38 times Was thanked: 24 time(s) in 20 post(s)
 1 user thanked pba for this useful post.
Joined: 4/28/2020(UTC) Posts: 43  Location: San Francisco Was thanked: 6 time(s) in 5 post(s)
I want to bump this as I think this is a need for troubleshooting.
Unless the ServerReflexive vs PeerReflexive info is an indicator?
DT
+1 Whereas p2p (STUN) now can be enforced, we still would like to know which type of connection is used after negotiation. That helps assessing reasons for quality differences as well as network configurations.
Joined: 5/17/2020(UTC) Posts: 23  Location: Berlin Thanks: 16 times Was thanked: 6 time(s) in 2 post(s)
Joined: 1/13/2010(UTC) Posts: 5,318  Location: Gold Coast, Australia Was thanked: 4720 time(s) in 1617 post(s)
Originally Posted by: DaveT  I want to bump this as I think this is a need for troubleshooting.
DT Yes this is the indicator, all you need to check is if this says "Relay" then it is using our servers. If not then it is always a direct connection.
Originally Posted by: admin  Originally Posted by: DaveT  I want to bump this as I think this is a need for troubleshooting.
DT Yes this is the indicator, all you need to check is if this says "Relay" then it is using our servers. If not then it is always a direct connection. So it is supposed to say PeerReflxive, and that then means it is connected direct? Where would I look for "Relay". I'm having some call connection issues, when I force the Peer connection only callers can't connect. I'm trouble shooting with my network team, would just love to know for sure where I can tell exactly what the connection is. Thanks!
Feature Requests
