DynamoBen
#1 Posted : Saturday, May 2, 2020 5:46:01 AM(UTC)
DynamoBen
Was thanked: 13 time(s) in 3 post(s)
I'm new to vmix and am trying to figure out how to play 5 audio files in a loops with a preshow graphic. I can do each independently via a playlist and input but cannot figure out a good way to combine them. Suggestions?
dmwkr
#2 Posted : Saturday, May 2, 2020 8:43:15 AM(UTC)
dmwkr
One way: You can load the audio files into a List and press the loop button on the input. In the input settings of your graphic place the list input onto one of the Multiview layers.
https://www.vmix.com/help23/VideoList.html
https://www.vmix.com/hel...utSettingsMultiView.html
thanks 1 user thanked dmwkr for this useful post.
jsharp on 5/4/2020(UTC)
DynamoBen
#3 Posted : Thursday, May 21, 2020 12:51:08 PM(UTC)
DynamoBen
I ended up doing it a little differently. I created a new List input with the audio files then added the graphic to the multiview settings of this input. Which seems to be working. Thanks for the direction!
