	vMix Call
	VMix Call Auto Audio Mix/ Audio Buses
                Hi All,
  Odd one
  I've been doing a show with 8 callers, all has been fine except the auto audio mixing.
  There are no triggers involved, but when I transition to any input that involves a caller (multiview or just the call) the audio from 1 or 2 other callers will switch on for some reason.
  Anyone else seen this happen?
  I know I could build it all with triggers, but the Auto mix should do this for me
  Cheers
                d Apologies idn't mention that I had done that,
  to explain a bit better it is mixing calls that aren't active
  All good, I just use triggers for the audio for now
	vMix Call
