Same vMix sending different outputs
Joined: 5/19/2020(UTC) Posts: 4  Location: SAO PAULO Thanks: 1 times Was thanked: 2 time(s) in 1 post(s)
Hello ,
Does any body knows how could I streaming same live event to two different destinations, being 2 different VT breaks in the same vMix workstation? Is it possible? The 2 different breaks would bet cutted at same time and would have same time length.
Yes you can stream to different destinations you can stream different outputs to different destinations
Hi @doggy thanks for your reply, the problem is, it is the same live stream to different outputs, but when I cut VTR break in one of then I need a different vtr playback in the other output when both vtr finish at same time still streaming same live content for both.... Do you know what mean?
Doggy is correct to suggest this video tutorial. It is up to you to configure you vMix workflow so that you have two independent streams (Output 1 and Output 2) that may share some content but not ALL content.
- Tom
