Joined: 12/7/2017(UTC) Posts: 47 Location: New Zealand
Thanks: 4 times Was thanked: 4 time(s) in 4 post(s)
Anyone had any luck getting NDI to work with AWS instances? Any help or pointers appreciated. I have two cloud based vMix switchers and am looking for a way to get NDI working between them.
Are they in the same VPC network and have the necessary ports open. Alternatively you can use SRT.
Joined: 5/10/2020(UTC) Posts: 104   Location: Sacramento, California Thanks: 13 times Was thanked: 5 time(s) in 5 post(s)
You'll need to open the have them in the same VPC, and open the correct ports in your security group. Also, you'll want to install NDI Tools on both instances and use Access Manager to add the IP addresses of your other instance(s).
 1 user thanked Geoff B for this useful post.
Thanks guys! Yes both in the same VPC and confirmed by web controller working in both directions. Access manager crashes when I select New in the remote sources panel. NDI Tools on both servers.
Joined: 5/28/2020(UTC) Posts: 35  Location: London Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Nakedeye
I'm not sure if I'm doubling up on software running, but I got this working yesterday thanks to this thread and Geoff's response.
Windows Defender might be causing a problem. Try disabling app control.
Also, have you got enough RAM on the instances?
I tried this first with a t2.micro instance (no cost - free tier) and it ran like an old dog. That's just to drive NDI inject of Zoom/web browser. Not vMix obviously!
Changed to a t3a.medium and it was a breeze.
Thanks for the post and glad you got it working. I am no closer to a resolution between my two server instances I have ports open and everything is on the same IP range and subnet. I can see each vMix systems web controller in the other server just no NDI. NDI Access manager crashes when trying to add external IP. The pop out panel doesn't show up and the main app screen just disappears.
Solved with NDI Tools 4.5. Thanks to all who helped.
 1 user thanked nakedeye for this useful post.
