cd6
#1 Posted : Sunday, May 17, 2020 12:13:51 AM(UTC)
cd6
I'm running the Pro version of vMix & wanted to figure out how the outgoing feed for vMix Call with multiple callers. To be exact: does vMix intuitively understand that I'm sending the same feed to 2-3 callers & combine them, or does it stream 2-3 separate streams?
#2 Posted : Sunday, May 17, 2020 1:00:25 AM(UTC)
@ cd6
Separate and independent return feeds, you can send each caller different audio and video return feeds.
xaver
#3 Posted : Sunday, May 17, 2020 1:46:15 AM(UTC)
xaver
Originally Posted by: IceStream Go to Quoted Post
@ cd6
I think he want's to know (and I'm interested myself also) if every caller gets the same feed back, can I save bandwith or is there really a sperate backfeed even when I send the same video and audio?
#4 Posted : Sunday, May 17, 2020 10:42:30 PM(UTC)
@ xaver
It is recommended you have 2Mbps upload/download per caller:
https://www.vmix.com/hel...index.htm?VideoCall.html
xaver on 5/17/2020(UTC)
DaveT
#5 Posted : Tuesday, May 19, 2020 3:38:24 AM(UTC)
DaveT
Outside of bandwidth, what about the actual encoding?
If I am sending multiple callers the same video/audio return feed (incl. same res/bitrate), does VMIX only encode it once and duplicate across the board (more efficient) or is it encoding separate feeds for each one using up more system resources.
DT
