Feature Requests
Ability to rotate, pan, zoom photos for photo slideshow
Please make it possible to rotate, pan, zoom photos within vMix.
Out of the three, I think Rotate is the most important. It appears that vMix currently determines which side is up based on some image metadata, and doesn't allow changing it within vMix. Sometimes, even if I rotate and save the photo the way I want it using a photo app outside vMix, but vMix still displays it in a different way.
Apparently, this makes it very difficult to use vMix's photo slideshow. So please please add this feature!!
Lastly, thank you as always for making this great product!
Jason
Joined: 5/27/2020(UTC) Posts: 14  Location: Dallas Was thanked: 5 time(s) in 3 post(s)
Agreed. Being able to zoom and reframe the image would also help with tall images in a landscape/wide show.
Don't you think it's much easier to use an Image Editor to make your images display correctly ? If your images are wrongly defined (portrait instead of landscape), it's not a vMix job to correct everything.... but to focus on Live Production.
Besides there are already severa ways to reframe, pan or zoom in a picture (or anything else). I once had a slideshow displayed in a circle... We can do almost everything in vMix, it's just a matter of fully exploring the possibilities, being creative, having the ability to think out of the box. Think of vMix as a LEGO box... with few elements you can do anything. But if your elements are broken, it's not a vMix job to fix them...
Joined: 8/16/2019(UTC) Posts: 357  Thanks: 80 times Was thanked: 24 time(s) in 19 post(s)
I usually create a new input (colour) and then use multi-view, then place the image on a layer two (usually layer two just in case I want a background), then I change the position that way.
Feature Requests
