spydervenom
#1 Posted : Saturday, May 16, 2020 2:00:45 AM(UTC)
spydervenom
In the attached images, you can see that there is a colored bar on the screen to let the camera ops know when they are live. Does vMix offer this feature? IMG_0235.jpg (446kb) downloaded 1 time(s). IMG_0236.jpg (407kb) downloaded 1 time(s).
#2 Posted : Saturday, May 16, 2020 2:34:48 AM(UTC)
Sure if you play with the API XML data
Think also Tally comes to mind ?
spydervenom
#3 Posted : Sunday, May 17, 2020 5:30:26 AM(UTC)
spydervenom
Thanks for your response!
As far as playing with the API XML data, would you happen to be able to point me in the right direction on how to learn to do that?
Thanks so much!
spydervenom
#4 Posted : Sunday, May 17, 2020 8:35:09 AM(UTC)
spydervenom
Thanks so much!
#5 Posted : Sunday, May 17, 2020 8:53:32 AM(UTC)
check out scripting for dummies post , there are a few examples there
There have been other posts too in this forum on how to display on screne for example is one is recording etc
also have a look at 127.0.0.1:8088/api to see all sorts of info regarding your current vMix setup
ps no need to post multiple times the same question if there is no reply within a few hrs, we all do other things too or are in different timezones ;-)
ask
#6 Posted : Sunday, May 17, 2020 8:58:45 AM(UTC)
ask
Leonid
#7 Posted : Sunday, May 17, 2020 2:15:11 PM(UTC)
Leonid
Canada
On the same topic, but a slightly different situation.
How do I include Live Streaming indication/status into any Web Controller page?
I've configured the Shortcuts/buttons to turn Stream ON and OFF, and they work fine, but after I press them, there is no indication of anything happening (on the Web Controller).
I need an indicator, so I can give access to someone to turn the Streaming ON and OFF remotely through the Web Controller - without access to vMix software.
Can be anything - pixel, number, picture, text, etc - as long as the actual status of Streaming is indicated.
Thank you,
Leonid
ask
#8 Posted : Monday, May 18, 2020 10:01:00 AM(UTC)
ask
