Joined: 5/15/2020(UTC) Posts: 2  Location: Covington, Tn. Thanks: 1 times
The virtual set camera has 4 settings F, M, S, & C. It would be great to have a fade to go with the others. I use a blank virtual set and use the 4 camera views for different camera angles, so having a fade would make it better to change between these camera views. I would also like to see 6 camera views instead of the 4 camera views.
Joined: 3/17/2017(UTC) Posts: 445  Location: Luzern - Schweiz Thanks: 69 times Was thanked: 57 time(s) in 51 post(s)
Joined: 12/27/2012(UTC) Posts: 5,451  Location: Belgium Thanks: 311 times Was thanked: 1006 time(s) in 830 post(s)
Originally Posted by: Jerry Boswell  The virtual set camera has 4 settings F, M, S, & C. It would be great to have a fade to go with the others. I use a blank virtual set and use the 4 camera views for different camera angles, so having a fade would make it better to change between these camera views. I would also like to see 6 camera views instead of the 4 camera views. Why even use a virtual set for that ? Just duplicatie the camera by creating virtual inputs of it , in your case 5 more times. position the cameras to your liking in each one and just fade between them (or any other transition) Use a spoon for soup, not a fork ;-)
Thanks for the information, only been using Vmix a few months so I'll give your way a try and see if that works better for me.
