Two Cameras with different latency one USB mic
Hello I have a latency issue that I hope someone can help with.
I have two cameras, one camera is NDI IP capture with 400ms latency. The second camera is USB capture device with 1000ms latency.
And I have audio input being mixed from GoXLR USB chat mic.
How do I change the mic delay when switching from one camera to the other?
I have tried to create two mix inputs in Vmix with the same source but that just seems to disable the first input when I create the second input using the same mic source.
I am new to vMix so any advice on how to solve using one mic input would be most helpful.
Thanks!
Phillip
Delay the fastest inputs to match the slowest
