Audio monitoring sped up via IO4K Plus Analog Ouput
Joined: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
I sent an email to support but I figured I'd try this here too.
The setup: Thunderbolt to IO 4K Plus to Analog XLR ouput. VMix Master output is set to Digital Audio Interface (AJA).
Everything is fine if I just restart VMix, but once the computer is restarted I hear sped up audio from all inputs VIA XLR out from the IO4K. Note that external embed audio to SDI is fine, it's just the Master output monitor.
The same thing happens if I select AJA output via Windows sound settings, but only audio from VMix is sped up, not local audio, so this is on the VMix side.
