Joined: 5/13/2020(UTC) Posts: 2  Location: Las Vegas Thanks: 1 times
Hello. I have a question. I have 3 camera inputs and a skype, ndi input. We live stream once a week. The computer with vmix leaves the studio. I would like to be able to preset the next show from home. I do not being the cameras home. So when I open the preset, vmix doesnt see the camera and I lose the place, which means I have to re program each multi view everytine. Is there a way to save these inputs without having the cameras hooked up. We are using a decklink quad for sci. And a decklink intensity card for hdmi in. Thanks
John
Thanks: 64 times Was thanked: 153 time(s) in 137 post(s)
You could change the camera inputs to colour inputs before the vMix PC leaves the studio, and vice versa when it gets back.
 1 user thanked dmwkr for this useful post.
I do not get that problem, because I save the preset with a specific name, and when I open, I look for that preset, and it opens....and if by chance it does not see the camera input, all I do is right click on the input window, and click reset, and if that does not work, there is another option, and I would use that to relink the camera..but the key is to save the preset with a name...I have many presets, and I do not get any issues ...for church, I open the church preset, and the inputs automatically connect....
Thank you for the quick replies. They are appreciated. I will try the changing the inputs to colors and see what I get.
