pldesigner
#1 Posted : Wednesday, May 13, 2020 5:06:34 AM(UTC)
pldesigner
Hey all!
Maybe this is a regular occurrence that I should've picked up on when reading the manual.
I've started using vmixcall for my last project. I also own a Blackmagic Intensity Pro HD PCI card.
Using that card has been fine on its own. But using it in conjunction with vmixcall calls it spelled total disaster, causing lag in the vmixcalls.
The vmixusers can be heard talking but the visual lag builds up to 15-20 seconds.
I think I tried Low Latency capture at some point but nothing helpful of note seemed to work...
The system has a 4th gen Hexcore i7 processor, 32GB Ram, nvidia GTX 1070 graphics card with 8GB Ram.
No other peripherals internally.
There's no time pressure (as the event has already taken place). This is me trying to educate myself.
Hope there's enough info here!
