Joined: 4/17/2020(UTC) Posts: 50  Location: Washington DC Thanks: 6 times Was thanked: 4 time(s) in 2 post(s)
Is there a technical reason why the position coordinates can not be named for humans ?
How about Left, Right, Top, Bottom, etc.?
Also... ARROW Keys
Can you please ADD the ability to make changes, moves etc. using the arrow keys ! It would be great if you can nudge things in small increments using the arrow keys instead of using the slider and numeric inputs.
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Originally Posted by: LeeL  It would be great if you can nudge things in small increments using the arrow keys instead of using the slider and numeric inputs.
Use the mouse wheel while hovering over the position indicator
Originally Posted by: LeeL  Is there a technical reason why the position coordinates can not be named for humans ?
No, you can easily change that in the language file if you so would like it differently
