Audio issue - looking for pointers
Hi Friends, I am hoping someone can point me in the right direction. This streaming thing is new to me and I have encountered as issue 3 times now that I cannot explain. I will test the audio and all seems fine but then for some reason all of a sudden it distorts. See here is a 20 second example I was playing a video prior to this and then i opened the audio in the room and it was a mess. My fix is to go to the input settings, press 'change' and select the same device again, press OK and all is good again. Any thoughts where I should start to look? If you notice a little cough before the piano starts it seems the distortion is only when there is noise. Thanks in advance. Brad
Originally Posted by: bigboybradders  My fix is to go to the input settings, press 'change' and select the same device again, press OK and all is good again. Any thoughts where I should start to look? I'm new to vMix as well but I've dealt with my share of audio issues in the past. If you're playing an audio/video on your computer outside of vMix your sound card driver might be causing a problem. When you say the problem is fixed when you "change" (reset) input settings again, it again makes me think your sound card driver causing a problem. I used to have an audio card that if I played an "outside" video or youtube web page outside the program I was working in it would cause my voice to speed up and get higher. I'd have to reboot my computer to fix it. If you have a different sound card you could test using it'd help isolate the issue maybe.
Thanks CorgieFan. I am actually using a DELL XPS 13 laptop thus it is entirely possible the internal sound card has the issue as I feel I am pushing the limits with an external monitor, stream deck, camera and mic, 2 streams etc. Originally I had separate mics which I stripped back to keep simple and hopefully avoid the issues but sadly they have continued. I have a error shortcut key set up ready should it happen in the middle of a stream and will continue to monitor. Thanks for the suggestion. Regards, Brad
I'd definitely try an external sound card then. I used to use a Focusrite Scarlett 2i2, I think vmix refers to using it in one of their videos as well. Huge step up from any internal sound card. Good luck.
