Joined: 12/4/2018(UTC) Posts: 52  Location: Brussels Thanks: 3 times Was thanked: 11 time(s) in 11 post(s)
So was just setting up a new multi view. Idea being to have the 4 outputs outputting via NDI so I could bring them back in and multi view them so I can keep an eye on whats going where. So far so good. Not sure at what point it happened, but suddenly i realized the full screen was outputting OUTPUT rather then multi view... but I can't change it back. Tried in the settings menu but no matter what I select it just stays on output. I've started a new session which has resolved it, any one have any idea as to what I did? or whats going on?
Also as a quick side question any one have a better workflow for monitoring the 4 outputs other then looping back in via NDI?
Thanks,
TobinT
So it appears to happen when I change output 1 away from output and lock that output to an input. At that point the full screen source switches to output and won' let me switch back to multi view until I switch the output 1 back to output.
Thanks: 38 times Was thanked: 39 time(s) in 35 post(s)
Just came across the same bug.
Groups:: Registered
Joined: 3/7/2012(UTC) Posts: 2,683  Location: Canada Thanks: 33 times Was thanked: 512 time(s) in 480 post(s)
@ all
Essentially, this is by design since the vMix Program Output has to go somewhere, which is by default Output 1, if that is changed for some reason, the Fullscreen will automatically become the destination for Program Output.
Joined: 3/31/2021(UTC) Posts: 1  Location: New Albany
I am having the same issue.
24.0.0.52
My GTX 1070 has 3 outputs on the card. when 2 of them are connected in windows, they see them correctly. in vmix fullscreen 1 can ONLY be output. it cant be changed. even in display where i can choose what output of the cazrds to use for FS 1 and 2. no matter what i select for FS1, its always output.
Any ideas on how to make it not only output?
