Feature Requests
Merge transparent problem
Hello Iam Joy I am using vMix Merge Transition in two multi view Now I'm facing a problem, when i click merge transition for input , its show me transparent few second...  Capture.PNG (549kb) downloaded 3 time(s).
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
That is what Merge does if you dont follow the description mentioned in the help files
The Merge effect is a unique transition effect that seamlessly animates matching Inputs between Preview and Output. In the above example ...... Any other layers or inputs that do not appear in both Preview and Output will transition using the Fade transition effect.
BTW as his is NOT a request for a new feature it should have been posted in the General Discussion tab
Feature Requests
