videokommando
#1 Posted : Monday, May 4, 2020 9:20:44 PM(UTC)
videokommando
Rank:: Advanced Member
In Skype Call there is no audio if the Headphone volume control is ON.
I must be switched off Headphone volume control.
Setting:
Main Master Output: Dafault Windows Playback Device
Headphones: Dafault Windows Playback Device
A Bus: Enabled
how does it work at once?
Thank you.
Narcogen
#2 Posted : Tuesday, May 5, 2020 12:20:06 AM(UTC)
Narcogen
Are you trying to record this call, or just communicating over Skype while operating Vmix?
If you're trying to record the call, you don't want to do this, as you'll likely be trying to record your default output at the same time using it for monitoring.
If not, then I'd go into your Sound control panel and make sure you've turned off device exclusivity-- you could be having this problem because Skype and Vmix both want exclusive access to your default device.
thanks 1 user thanked Narcogen for this useful post.
videokommando on 5/5/2020(UTC)
videokommando
#3 Posted : Tuesday, May 5, 2020 6:25:54 AM(UTC)
videokommando
Originally Posted by: Narcogen Go to Quoted Post
... go into your Sound control panel and make sure you've turned off device exclusivity
Yessss! Thank you. :)
It works.
