Is vMix the right program for this task?
Hello everybody!
I'm currently looking for a video mixing program which can perform the following task
- I have on HD Camera with a HDMI output which I want to connect to my Windows Laptop. - In vMix I want to split the live image into 3, maybe even 5 parts and than be able to move them around independently - I want to save certain screen positions of the parts so I can jump to them - I want to animate the screen movement of the parts and replay it - I want to project it via my hdmi output
If vMix is able to perform this task which version do I need?
Can you recommend a inexpensive USB (2.0 or 3.0) Video grabber device that works with vMix so I can capture the live video? I don't need broadcasting quality.
Thank you very much!
Greetings
schischu
schischu wrote:Hello everybody!
Greetings
schischu yes i would also like that making this already cost effective ( non hd version ) even better.
Joined: 6/29/2011(UTC) Posts: 316   Location: Florida Thanks: 6 times Was thanked: 35 time(s) in 34 post(s)
- In vMix I want to split the live image into 3, maybe even 5 parts and than be able to move them around independently - I want to save certain screen positions of the parts so I can jump to them - I want to animate the screen movement of the parts and replay it Could you create an example video showing what your trying to do? and post a link to video here.
