NTSC
#1 Posted : Monday, May 4, 2020 12:52:25 PM(UTC)
NTSC
Is there a way to rearrange the audio inputs or group them visually?
sinc747
#2 Posted : Monday, May 4, 2020 4:12:18 PM(UTC)
sinc747
The audio inputs appear in the order that they were added to your vMix desktop as Inputs. For example, a video (with audio) would have both an Input in the bottom left section of the vMix desktop and an Audio Input in the Audio Mixer section.
To rearrange the order of the Audio Input, simply drag and drop the regular Input (not the Audio Input) to a new position. As an alternative, you can right click on the Setting Icon for an Input and assign it a new position #.
- Tom
Joeboe
#3 Posted : Monday, May 4, 2020 10:41:16 PM(UTC)
Joeboe
You can also use a third party software to control the audio...I use vMix Panel Builder, found in the third party section on the forum....It is free, and very easy to set up...I use it for all controls of vMix, but you can build one just for audio, and label each input as you wish.I even comes with a video list setup so you can arrange your video in the order you want them to play, and can do a direct select from the list.......see the last page of that forum, and see two examples of the Panel Builder...
NTSC
#4 Posted : Tuesday, May 5, 2020 8:31:38 AM(UTC)
NTSC
Thank you! Both very helpful replies.
Guest (5)
