Joined: 4/12/2020(UTC) Posts: 11  Location: London Thanks: 2 times
I bought a (cheap) action cam (Victure AC600) for use as a webcam. It works when tested in Windows and in OBS but not in vMix. When I attempt to add it as an input it shows up as iCatchtek SPCA6350. When I then try to save the input I get the error message: Could not Render Output. AddNewInput INPUT_CAPTURE No such interface supported.
Is anyone aware of a fix? Thanks.
Update: I have found a workaround which involves using an OBS Virtual Camera as an input in vMix, though this seems rather unwieldy given that both OBS and vMix have to be running simultaneously..
