artciukas
#1 Posted : Friday, January 3, 2014 10:53:27 AM(UTC)
artciukas
Hallo,
Please help me. I can't understand why multicoder skiping frames. With DV encoder the same problem...
Log1:
1/2/2014 6:16:25 AM, Version: 11.0.0.63 x64
1/2/2014 6:16:25 AM, Size: 1920x1080
1/2/2014 6:16:25 AM, System: PAL 50i or 25p
1/2/2014 6:16:25 AM, Codec: GoPro-CineForm Codec (x64) v8.6.3
1/2/2014 6:16:25 AM, Format: UYVY 16 1498831189
1/2/2014 6:16:25 AM, RestartInterval: 0
1/2/2014 6:16:26 AM, StartRecording
1/2/2014 6:16:42 AM, StopRecording
1/2/2014 6:16:42 AM, Duration: 00:00:16
1/2/2014 6:16:42 AM, Frames: 392
1/2/2014 6:16:42 AM, DroppedFrames: 8
1/2/2014 6:16:42 AM, DueToSourceFrameRate: 8
1/2/2014 6:16:42 AM, DueToHardDiskOrCPU: 0
Log2:
1/2/2014 6:16:26 AM, Version: 11.0.0.63 x64
1/2/2014 6:16:26 AM, Size: 1920x1080
1/2/2014 6:16:26 AM, System: PAL 50i or 25p
1/2/2014 6:16:26 AM, Codec: GoPro-CineForm Codec (x64) v8.6.3
1/2/2014 6:16:26 AM, Format: UYVY 16 1498831189
1/2/2014 6:16:26 AM, RestartInterval: 0
1/2/2014 6:16:42 AM, Frames: 398
1/2/2014 6:16:42 AM, DroppedFrames: 0
1/2/2014 6:16:42 AM, DueToSourceFrameRate: 0
Log3:
1/2/2014 6:16:41 AM, StopRecording
1/2/2014 6:16:41 AM, Duration: 00:00:16
1/2/2014 6:16:41 AM, Frames: 383
1/2/2014 6:16:41 AM, DroppedFrames: 15
1/2/2014 6:16:41 AM, DueToSourceFrameRate: 15
1/2/2014 6:16:41 AM, DueToHardDiskOrCPU: 0
What means: DueToSourceFrameRate and how to fix this problem.
I use Blackmagic minirecorder 3 cards for inputs.
I try everything but nothing. Sometimes skip 1 frame but mostly many frames. This is happening since the start of record. Graphics card: GeForce GTX 770 with 4 GB memory.
vMix is powerful software but won't work correctly (for me) :(
#2 Posted : Friday, January 3, 2014 11:23:32 AM(UTC)
When multicorder is stopped but all the cameras have been added to vMix, wait 5 minutes
and then take a screenshot of the Statistics window (click the colour bar button in the bottom right hand corner of vMix)
artciukas
#3 Posted : Friday, January 3, 2014 12:19:26 PM(UTC)
artciukas
Hallo Martin,
At this moment i don't have connected cameras but add three decklink capture inputs to vMix (without video). Ok for this test?
I wait more then 10 minutes. Print screen:
https://www.dropbox.com/...014-01-02%2008.01.39.png
Dropped just 1 frame.
After 1 h. 5 render droped frames and the same 1 source dropped frame.
When i change performance setings after 30 minutes print screen:
https://www.dropbox.com/...014-01-02%2010.36.51.png
Thanks for answer
artciukas
#4 Posted : Tuesday, January 21, 2014 6:06:19 AM(UTC)
artciukas
Hallo,
What about test results Martin?
#5 Posted : Tuesday, January 21, 2014 6:39:33 AM(UTC)
The test results will need to be with cameras plugged in and sending video.
The blackmagic driver does different timing when nothing is plugged in.
artciukas
#6 Posted : Tuesday, January 21, 2014 7:28:59 AM(UTC)
artciukas
Ok,
Video signal can be from tandberg rx8200 receiver or it will be necessary cameras signal? (is the difference?)
Arturas
